Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
Thanks so much for having a place for us propeller heads to hang out and chat.
Geography
socalpt (Industrial)
20 Nov 08 15:54
Can someone tell me what are the methods for 3D constraint in sketches?
rollupswx (Mechanical)
20 Nov 08 17:43
I almost always create 2D sketches to control my 3D sketches.  Can you attach a sample file that you are having trouble with?
20 Nov 08 18:20
I am doing a simple pipe run but I don't know how to use the constraint to make the lines parallel to the Axis.
20 Nov 08 18:21
20 Nov 08 19:09
I assume you are not using Inventor Routed Systems with the piping module.  You need only create 2D sketches with points dimensioned for the bend intersections.  Then create 3D sketch with bend activated to do your path.  The advantage to this method is it is trivially easy to edit.  What release of Inventor are you using?  Perhaps I can work up a quick example.
21 Nov 08 10:29
I'm using IV2008.
Close Box
Join Eng-Tips® Today!
Join Us             Close
