Quick release bolting
I have a studded access door that requires unbolting for inspection.  Besides replacing the door with something different (hinged etc) does anyone know if there's such a thing as a quick release nut that will use regular coarse thread.
RE: Quick release bolting
Thirty years ago, I had an Australian Repco cylinder head reconditioning machine that had quick release hex nuts on its fixturing. These had a slanted clearance hole like those in ajack1's link above. They worked well, but they felt a bit spongy and tended to deflect the stud at the outer end due to the one sided thread, I would be reluctant to really torque them down.
There is a design of nut that avoids this problem and looks a lot stronger, although I've not had any occasion to try them and they're probably a lot more expensive.
http://www.wixroyd.com/products/pdf/w__205-206-collar-nuts.pdf
Trevor Clarke. (R & D) Scientific Instruments.Somerset. UK
SW2007x64 SP3.0 Pentium P4 3.6Ghz, 4Gb Ram ATI FireGL V7100 Driver: 8.323.0.0
SW2007x32 SP4.0 Pentium P4 3.6Ghz, 2Gb Ram NVIDIA Quadro FX 500 Driver: 6.14.10.7756
Ajack - that's more of a no tool nut but in the application it would be difficult to use.  Thanks though.
SinoTC - thanks - that's just the sort of thing I was looking for.  Very interesting design.
Search www.mcmaster.com for "quick-threading nut", then see if the hex slip-on nut will work for you.
Hello Pulpeng,
It's a relatively costly option but, have you considered Hydraulic Nuts?
Actual "tightening" and "untightening" is the biggest user of time in any such process - even with slip-on nuts as described above.
Hydraulic Nuts replace standard hex nuts. Once they're all spun down, they're connected in parallel to a common pump. This pump applies pressure to simultaneously stretch each nut. When the required preload has been applied (usually in mere seconds), one simply turns down a locking collar which retains the load. Dissassembly works in reverse: The quick-connect harness is attached, pressure is applied, the locking collars are turned back, the harness is removed and, the nuts are spun off.
Not only is this a "quick" process, it also results in a known applied load providing even gasket compression winky smile
Ciao,
HevïGuy
www.heviitech.com
How about wing nuts?
Hevii Guy - that seems more complicated for what I'm looking for.  All I'm after is securing hatches on conveyors/chutes etc quickly without changing hardware to handles/clamps etc.  Part of the problem comes from too long of studs, dirty studs or damaged studs.  They are just a pain for operators to remove 16+ nuts with a crescent and they are looking for hinges etc.  I'd like to offer them SINCOTC or Madmango's suggestion.  Both are good.
Thanks for everyones help though.
How about dzus fastener?
Joe
SW Office 2008 SP5.0
P4 3.0Ghz 3GB
ATI FireGL X1
Another possible and cheap solution is to drill out the clearance holes to larger than the nut and simply buy or manufacture washers shaped like a C, undo the nut half a turn and slide the washer out.
Search for "Quick-Threading Nuts" at:
http://www.mcmaster.com
Hex slip-on nut is possibly what you are looking for.
If these are just hatches, can you drill the studs to accept a safety pin and use that with a fender washer and a rubber washer (to put some preload on it to keep from rattling)?
How about the levered nuts used to hold bicycle wheels on their axles.  Once the lever is released, they can be spun off by hand.
TTFN
