Allowable Primary and Secondary Stress in Cold Service
An existing carbon steel vessel, which was not impact tested, is being evaluated for suitability.  Desired MDMT is -150 F.  When operation will occur at this temperature general membrane stresses are such that the ratio as shown in Figure UCS-66.1 is less than 0.35.
Local stresses at nozzles and saddles will be evaluated using FEA and following Division 2 rules, but using the Sm value from Division 1.
Question:  For Primary and Primary plus Secondary Stresses is it appropriate in this case to use 1.5 times Sm and 3 times the average of Sm (cold) and Sm (hot) as prescribed by the Code for the allowable local stresses?
