Determine load rating of a lifting beam
I have a lifting beam that is detailed in the attached sketch (5/8" thick flat steel plate, 4'-1" long, 4" high, with 1 Lug Plate in the center). I to determine what the load rating would be on this. Any help with calculating this would be great.
RE: Determine load rating of a lifting beam
the beam does look narrow, "tippy" ... from your sketch i take it that the load is reacted at a pair of the grooves ? i guess you could consider the beam has fallen over (so the load is applied across the weak axis of the beam ...
Without doing any calculation, that beam does not look right. An I have seen a few lifting beams in my travels. Having said that, the loads you talk about (4000lb) is punny.
The beam has very little stability, and since the grooves are on the top of the beam I would assume that the load is applied above the CoG and hence de-stabilising. Moving the application point of the load to the underside of the beam would help.
Is the load secured to the lifting beam? The grooves seem to indicate that the load is just hanging from the beam, saddled in one of the grooves. In that case a sudden movement, unequal loads or beam defflection would make it fall. Not a good thing.
I highly recommend modifying the detail (even if structurally you can make it work). Holes drilled on the bottom part of the beam allow you to put the shackles and ensure that they will not move
Single point lifts are very unstable, if the beam tilts as it is likely to do when the equilibrium of the lifting arrangement changes so the COG of the lifted object is below the lift point. The tilt may force your slings out of the grooves on the top.
For there to be any torsion generated in the beam there must be some torsional restraint, otherwise the beam will just rotate. Your loads are all applied in a line on the top flange. I cannot see how you have any torsion.
Also, are you lifting the object (ie attaching to it) above or below its COG? If you are lifting below the COG then any misalignment may cause the load to topple (depending on geometry).
