Plate material for welded large diameter pipe
hello, a query regarding piping material.
I need to do purchase spec for 74" and 65" lined pipe for petro-chemical plant.Pressure is at 345KPag and metal temperature is 260 degC.
My question is how to specify CS plate material.
Is there a similar ASTM spec to A53/A106 for smaller size?
--It boils down to simple math--
RE: Plate material for welded large diameter pipe
If you are buying pipe, why specify plate?  Why not select a pipe specification that takes care of the starting plate; for example, ASTM A672.
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
is this a DIY job?
"Pumping systems account for nearly 20% of the world's energy used by electric motors and 25% to 50% of the total electrical energy usage in certain industrial facilities." - DOE statistic  (Note: Make that 99.99% for pipeline companies) http://virtualpipeline.spaces.live.com/
