Concrete Cover Below Ground
When designing RC columns that start at foundation level, do you increase the cover for the reinforcing below ground? And then change it higer up only? Is it an option to investigate the the cost effectivenes of using some specialist cover enhancer to the sections of reinf below ground and in this way keep the cover consistant?
RE: Concrete Cover Below Ground
Decrease the cover above the floor, if it is critical, or increase the column size below the floor (thereby increasing the cover).
