rs logic 500 analog input code
Any ideas would be helpful, Was wondering how to get started cutting code for an analog 4-20 input from a flow meter which will wind up controling an AC drive for A mill that is located downstream of the flow meter. End result requires constant flow to mill to prevent mill from running without product flowing to it. Thanks in advance.
RE: rs logic 500 analog input code
