Detecting Presence of a Chemical
Is there a chemical that can detect the presence of ethylene glycol in a solution? Ideally this would be something that changes color (or other visual indication)if there is greater than some concentration of the ethylene glycol in the solution.
I have done some searching for this, and it appears that the test strips that are available mainly try and show either PH, or concentrations of E.G. I am looking for something that merely shows that there is some presence, perhaps on the order of pp thousand or hundred, not ppm or ppb levels of sensitivity.
Really I am looking for a relative result, not necessarily something that has an absolute measurement. This would ideally be a chemical that could be placed on a test strip, inserted into the fluid and checked to confirm or deny the presence of EG (ie only one "pad" on the test strip)
Thanks!
RE: Detecting Presence of a Chemical
Most (all?) automotive grades of ethylene glycol contain a fluorescent tracer dye.  It should be fairly straightforward to create calibrated test tubes of known concentration (e.g. 10%, 1%, .1%, etc.), and use them to compare to an unknown sample when all are exposed to a UV light (black light) source.
Beyond that, you might contact Drager to see if they have a vapor detector that is sensitive to glycols.  You would then proceed the same way, i.e. at a given temperature of a known sample, pull x mL of air/vapor from above the sample thru the tube.  Once you've established a correlation of vapor concentration (as indicated by the tube) to liquid concentration, you could proceed to measure unknown concentrations in samples.
Wouldn't the test strip that shows concentration work?
If you get any indication it would signify that EG was present.
If it is important enough to warrant a small investment you could look at Refractometers.
unclesyd- cost is driving the concentration issue. It is too much information for my application.
Thanks for the advice so far guys!
