Can I See Two Different UG Parts In Cascaded Windows InOne UG Sessio
I am using NX5.0.4.1. If I have two models in NX and I can see each one through pulling down the window command and selecting the part.  Is it possible to see two separate models each one in a cascaded window? Two windows tiled horizontally in that single NX session ?
RE: Can I See Two Different UG Parts In Cascaded Windows InOne UG Sessio
Easy way to do something similar is to open a new session of ug and open your parts on that session.
I use two monitors which is great.
P.S. The second session does not consume an additional license so you can open several at no additional cost.
The most common and useful strategy that I employ is to open versions of the same part in different sessions when modelling changes to sequences of features that I might otherwise struggle to follow.
Limitiations may unfortunately apply to users of Teamcenter in that regard.
Cheers
Hudson
