Non-Diaphragm Building
We are designing a non-diaphragm building, i.e. steel skeleton building with no diphragm. Would appreciate if you could share your experience and shed some lights into:
1. for gratings clipped on steel beams, do you typically use grating as beam top flange bracing for LTB?
2. What do you usually do for lateral load transfer? What kind of horizontal bracing scheme do you typically use?
3. Any good recommendation on books for this type of structure?
Thanks in advance. Any input would be very much appreciated.
RE: Non-Diaphragm Building
