How to print all sheets in a drawing.
Does anyone know how to setup for printing all sheets at once.
RE: How to print all sheets in a drawing.
By using sheet set manager, among other great uses you can print an entire set of plans by using one command. I have mine set up for Full Size plots and one set up for half size to the printer. You can also select just the drawings in the set that you want a print of and then send them all at once.
http://www.theswamp.org/index.php?topic=1916.0
