How to use macro or journal to import parasolid then save to .prt
I am trying to create a macro or journal file that will import a parasolid file (with user selection to the specified file) and then save it as a UG .prt file in the location i select.
I am having problems with it opening the same parasolid with no user selection.
Here is the macro.
NX 5.0.4.1
Macro File: C:\Documents and Settings\j\Desktop\test.macro
Macro Version 7.50
Macro List Language and Codeset: english 17
Created by j on Wed Nov 19 08:09:32 2008
Part Name Display Style: $FILENAME
Selection Parameters 1 2 0.253752 1
Display Parameters 1.000000 14.025591 8.927473 -1.000000 -0.636513 1.000000 0.636513
RESET
MENU, 0, UG_FILE_IMPORT_PARASOLID UG_GATEWAY_MAIN_MENUBAR !
FOCUS CHANGE IN 1
FOCUS CHANGE OUT 1
FOCUS CHANGE IN 1
FILE_BOX -2, L:\CAD\101a FIXED HOLDER BLOCK.x_t  L:\CAD\*.X_T  1 ! Import Parasolid File
MENU, 0, UG_FILE_SAVE_AS UG_GATEWAY_MAIN_MENUBAR !
FILE_DIALOG_BEGIN 1, ! filebox with tools_data
FILE_DIALOG_UPDATE 2
FOCUS CHANGE IN 1
FOCUS CHANGE OUT 1
FOCUS CHANGE IN 1
FILE_DIALOG_END
FILE_BOX -2, L:\CAD\101a FIXED HOLDER BLOCK  L:\CAD\*.PRT  1 ! Save Part File As
