Matrix declaration in c-file for creating dll
I want to make a dll for a VB program. The c-code below shows wrapper file with variables a and b. What code I have to build if I use matrixes instead of doubles?!?
#include "eigenwaardelib.h"
#include "matlab.h"
double __stdcall eigenwaardewrap(double a, double b)
    mxArray *a_ptr;
    mxArray *b_ptr;
    mxArray *y_ptr;
    double *y;
    double ret;
    /* Create an mxArray to input into mlfeigenwaarde */
    a_ptr = mlfScalar(a);
    b_ptr = mlfScalar(b);
    eigenwaardelibInitialize();
    y_ptr = mlfEigenwaarde(a_ptr, b_ptr);
    /* The return value from mlfeigenwaarde is an mxArray so we must extract the data from it */
    y = mxGetPr(y_ptr);
    ret = *y;
    /* Return a double precision number to Visual Basic */
    return(ret);
RE: Matrix declaration in c-file for creating dll
Do you want a_ptr & b_ptr to be matrices? Use the command:
a_ptr=mxCreateDoubleMatrix(nrows,ncols,MX_REAL);
Then you'll need to retreive a pointer to the mxArray to populate it with values (ap=mxGetPr(a_ptr)). The array is 1-D, so you can set index (2,3) to 1.1 with the command   ap[(3-1)*nrows+2]=1.1
--Remember, MATLAB is columnwise, so it goes down the 1st column in the matrix, then the next, and so on.
