Heating water with steam.
Hi All,
I'm looking at heating inlet water using a steam stream.
The feed water entering my test module will be at room temperature and it needs to be heated up to 80 deg C.
How can I come up with the steam rate etc required to achieve this ?
Thanks a lot folks.
Cheers !
Thanks a lot folks.
Cheers !
RE: Heating water with steam.
If the heating of the feed water is by direct contact, equate the sensible heat of the feedwater gained in heating up to 80 deg C with the enthalpy difference of the condensing steam between the vapor state and that of water at 80 deg C.
http://
http://www.s-k.com/pages/pro_04_00.html
I shall come up with a value and get back to you guys if i need mroe help.
