PW Bug
PW Bug
I found a PhotoWorks bug on my system with '09 sp1.0, and I was just wondering if anyone else noticed it.  If you select PW Studio, in the Property Manager there is a preview of a tea kettle with the properties that you have selected.  That preview does not change or update with your selection as it did in '08.  If you double-click on the image a small preview window will pop up that is updated correctly, but the kettle in the PM doesn't.
It doesn't really affect anything as everything renders properly and shows up correctly in RV.  It's just plain annoying.  Anyone else seeing it?
Dan
www.eltronresearch.com
Dan's Blog
RE: PW Bug
Immediate update:  it may be an issue with my system.  I minimized the SW window and when I maximized it again the kettle in the PM has updated.  Also, if I move the preview window from the double-click over the kettle in the PM then move it away, it will update.  Strange.
Dan
Dan's Blog
RE: PW Bug
I haven't.  I find it annoying and all but useless, but as a diagnostic I'll check it when I get back to work.
Dan
Dan's Blog
RE: PW Bug
I updated my graphics driver this morning and all seems to be going well...so far.  Rob, before I updated the preview window was working as expected.
Dan
Dan's Blog
