Steel call out on drawing
I'm having trouble finding this for one of my customers and a material call out they need for a washer.They are requesting SPC590 for the part. They were using DC01-C490 but changed the spec to a SPC590. My manufacture has no idea what the spec is and I need an answer to clarify my manufacturer as well as my customer.Any ideas anyone
RE: Steel call out on drawing
SPC 590 is a partial designation from Japanese-based steel standards.
S = steel
P = plate (actually sheet, while other forms would be bar, wire, tube, etc.)
C = cold rolled
590 = minimum ultimate tensile strength in MPa
Here is one of many products that are in this class:
http://www.ussteel.com/corp/auto/tech/grades/advanced/dual-ten_590-600.asp
DC01 is a partial designation from Euronorm steel standards.
D = flat products for cold forming
C = cold rolled
01 = code for mechanical properties
You need to obtain full specifications of the materials to move forward.
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Thanks Cory for the info I will pass it along to my customer
Doug
The real designation is SPFC590 according to JIS G 3135.  As CoryPad mentioned it is a high yield strength steel typically used in automotive forming.  JFE Steel is a Japanese producer of this type of steel (their version is called JFE-CA590).  Check out pages 5-9 of the following .pdf file for more information:
http://www.jfe-steel.co.jp/en/products/sheets/catalog/b1e-002.pdf
