Low Volume Gear pump
I am trying to find a fixed displacement pump to pump lubricating oil. What I have pumps about 2 GPM, and I need something around 0.2 GPM or 12 GPH (gallons / hour) at 100 PSI or above. I am using a http://www.dmic.com gear pump. Does anyone have any recommendations of a pump to use?
RE: Low Volume Gear pump
Viking, Liquiflo etc. make small gear pumps. Good luck in your search.
http:/
Ted
