Stainless Steel for Cryogenic Application
I need to select a stainless steel grade for a cryogenic application. We use liquid nitrogen to drop the temperature of a steel pipe in order to remove an lining inside the pipe (differential thermal expansion causes cracking & thus removal). We load the tank with steel tubes at room temperature then close the lid (not pressurized, just an insulated lid) and start filling with liquid N2. After a while we remove the tubes and remove the lining from the tube.
We currently use a carbon steel tank and much to my surprise it has worked for many years. We are replacing it and I want to use a proper tank liner material. Based on what I've read it should be an austenitic stainless steel. Is there a preferred material type? Is 304 or 316 better?
Thank You
Thank You
RE: Stainless Steel for Cryogenic Application
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
