Flare Bevel void fill
If I need to weld two members together and has a large radius, can I specify a backer rod to fill in the void provided the weld attaches the rod to both members and extends over the top of the backer rod?
RE: Flare Bevel void fill
It's something else, and will behave differently than a flare-bevel.
Can you come back with some more information sizes and material?
A rod isn't normally used for a backing ring. Look at the site below for some acceptable shapes for backing rings.
Most codes require that if you use a backing ring you have to use a welding procedure that qualifies the use of same.
http://www.robvon.com/
What you are proposing may prove highly similar to slugging a weld in actual practice, resulting in cracking and weld failure in service (depending on the service conditions). As a general rule, I would recommend against it.
