How would I build a house on CATIA with 3 different people?
I've been instructed to design and build a house. I have 3 group members so we decided to divy up the work between the basement, first floor, and second floor. How would I divy up the work and still be able to connect each part into one file on CATIA?
RE: How would I build a house on CATIA with 3 different people?
I'd do the thing myself but I don't have easy access to CATIA whenever I want.
The cons are, the high price point, difficult installation, hard to learn (relatively).
if that's not an option. then consider skeleton modeling. The idea; you create one part with all the necessary info and have everyone in the team insert a copy with a link to that skeleton model. it takes more effort to get this method to work and you have to have your design intent clear upfront.
http://mtm-cadtutorials.blogspot.com/
A simple approach to work together is to meet up and define a geometric skeleton which drives all other parts in the assembly and sub-assemblies and then each of you go off and build parts based on this skeleton.
