SW2009 Mismatched Origins Of Inserted Part
Anyone noticed that the origins aren't aligned correctly when inserting a part into an assy, or when creating an assy from a part? I'm using the 'Click the Tick' method to accepth the default placement.
Didn't this also happen with a previous release?
RE: SW2009 Mismatched Origins Of Inserted Part
mncad
I brought it up to my VAR and SW and it didn't seem to be a problem with them at the time.
They suggested that I don't determine design around the origin!
Chris
SolidWorks/PDMWorks 08 3.1
AutoCAD 08
ctopher's home (updated Aug 5, 2008)
ctopher's blog
SolidWorks Legion
Say WHAT!!!
Design intent literally forces me to design around the origin. Glad I have never had the problem.
Timelord
One reason why I'm happy not to be with that VAR anymore.
Chris
AutoCAD 08
ctopher's blog
SolidWorks Legion
Scott www.earthtrucks.com
Solidworks 2007 sp2.2
Nvidia Quadro FX 1500
Dual PentiumD 3.00ghz 2 Gig Ram
I discovered last night, that if an empty assy document and part(s) for insertion are tiled when inserting a part, the origins align correctly.
I will be submitting an SPR later today.
FAQ559-507: Alternative to try before reinstalling
SW2008 Office Pro SP4.0
Intel Core 2 Duo CPU
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
Jeff Mowry
www.industrialdesignhaus.com
A people who value security over freedom will soon find they have neither.
It's only an issue on some PCs. The vast majority of users have never experienced the problem.
It also depends how the part is created with respect to its own origin, and how the part is "plopped" into an assy.
Are you talking about the first part placed into an assy?
If so, how are you placing it?
Yes, it doesnt happen all the time but it has definitely happened to me. I am aware that if i create a solid away from my origin it will insert itself away from the origin in the assembly but this happens also with parts that are origin-centric.
This is one of those things you just learn to accept and live with, kind of like "Failed to Save".
2.2GHz, 2.00GB RAM
QuadroFX 3700
SpacePilot
Can anyone else repeat this?
