Modeling a symmetrical part
I'm modeling a part that essentially looks like a three-leaf clover. Due to the symmetry, I've only sketched 1/6 of it, and should be able to form the rest through a combination of mirroring (to form one leaf) and patterning (to duplicate the other two).
My questions are:
1. Is it better to, (a) mirror and pattern the 1/6 *sketch* (to form a sketch of the whole part) and then extrude that into a 3D solid, or (b) extrude the 1/6 sketch into a 1/6 solid, then mirror and pattern it?
2. If I want to edit the sketch that a solid was extruded from, how do I get back into the sketch mode? I looked in PathFinder expecting to see some reference to it, but there wasn't any.
Thanks for the help. -Pat
My questions are:
RE: Modeling a symmetrical part
KENAT,
Have you reminded yourself of FAQ731-376: Eng-Tips.com Forum Policies recently, or taken a look at posting policies: http://eng-tips.com/market.cfm?
I did figure out (2) (RMB > Edit Profile), but still not sure about (1).
Thanks.
Pat
I've always been cautioned against mirror, but that doesn't mean I can justify why.
Try creating the 1/6 feature, then mirroring to get a complete leaf.
Then do a pattern (by default it tries to do quick pattern which probably wont work for this feature so you'll have to change to smart pattern) to create the other 2 leaves.
This may not be the best way but give it a go and see what happens.
KENAT,
So how do I simply duplicate a solid in a circular array about the z-axis? I'm guessing it's easy to do, but just poorly documented.
Pat
I've not used 'V21' so can't be more definitive.
KENAT,
-- 'Pattern command (Feature)'
scroll a bit down and you should find some examples
of how to pattern a feature in a part
dy
If they are circular I would probably just create the profile as 3 overlapping circles, trim and constrain, and extrude that as a single feature.
See attached pic.
To get back to the profile (I assume you didn't create a seperate sketch) RMB on the feature and then select 'Edit Profile'. You will also see 'Edit Feature' which will take you back to a position to edit any part of the feature creation, and 'Dynamic Edit' which will display the profile dimensions.
A double cick on the feature will also display the profile dimensions.
If you multi-select features and RMB > Dynamic Edit the dims will be displayed for all features selected.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
My profile is a little more complicated though. I'll post a picture of it so you can see. To do that though, I'd like to know how you generated your screen capture. Is that something built in to SE?
Also, I really like your light-blue background (looks better than the default gray one, imo). How do I change mine to look like yours? I looked in SE options, but didn't see anywhere there to do that.
Pat
Screen capture - I used File > Save As Image.
Click the Options button to set image properties.
Alternatively, if you want the whole screen use Print Screen on the keyboard, then paste into Paint or whatever.
The background is the default for V19 & V20 (I think).
It will depend on what you have set in the template.
To change it Tools > Options > Colours > Background.
You may then have to go to Format > View > Background > Type
and change it to Gradient.
As I said, I often change mine to SE Classic.
bc.
Quadro FX4600.
Attached is my profile. Any advice is appreciated.
Pat
Are the 30deg lines the lines of symmetry?
If so I think you are on the right track - create this protrusion, then use mirror about the LH line.
Next do a radial pattern of the original & the mirror.
bc.
Quadro FX4600.
I mirrored abot the RH line, then created pattern.
By the way, its probably best to use jpg files rather than bmp's as they're smaller.
bc.
Quadro FX4600.
Anyway, thanks for the feedback. I appreciate it.
Pat
Basically the steps are:
1. Select features
2. Select plane for profile
3. Select linear or radial pattern (I will assume radial)
4. Select whether to pattern full circle (ie 360deg) or along an arc (less than 360)
5. Select whether Fit or Fill and enter number of instances - suggest looking in help and playing with these.
6. Position centre of pattern, and edge of circle.
7. Select Fast Pattern (default) or Smart pattern to complete.
Generally you will need Smart Pattern.
Fast was supposed to reduce data size, but only seems to work on very simple things.
bc.
Quadro FX4600.
That's what I thought, but I noticed I could grab and move the dots around, changing their positions, without it effecting the positions or orientations of the parts in the final pattern. So I'm not so sure. Perhaps there another setting that need to be active. The only thing I did notice is that if I dragged the circle off center, then the patterned parts shifted accordingly.
Pat
That's because the centre of the circle defines the rotation axis and should be constrained accordingly.
The circle diameter isn't really important but define it anyway.
I just had a play to see what the dots are as I never really took much notice of them before.
When you place the pattern circle a dotted line is shown from the centre to the cursor position.
When you click to place the circle edge, this will become the start point of the pattern, and is shown by one of the dots. I think the other is just a keypoint.
In some systems you need to define a rotation axis by selecting a cylindrical face or an edge or by creating an axis element.
SE doesn't work that way, you define the axis by the position of the pattern circle.
On the circle you should also see a direction arrow.
bc.
Quadro FX4600.
What I was expecting is that the starting point would also define the starting position as well. For example, if the starting point was in the 12 o'clock position, then the first object would be in the 12 o'clock position; if in the 8 o'clock position, then the first object would be in the 8 o'clock postion, and so forth. That would be useful. But from what I've seen, the starting point location is arbitrary and has no effect on how the final pattern looks. So why ask for it? For patterning an object in a 360° array, only two pieces of information are really needed - the centerpoint and the number of instances.
I've also noticed that after clicking a point for direction, the prompt says to "Click on elements, Click & Drag for rectangular fence, or Alt + Click to place the first vertex of a polygon fence". Do you know what that is about?
Given how well thought out the rest of the application seems to be (at least the parts I've tried), I'm surprised SE makes what should be a simple operation this confusing.
Pat
As you say, for 360° patterns the start point etc doesn't make any difference, but when you use the arc option they do.
Try this - I created a rectangular block to do it on.
Create a hole at the 12 o'clock position.
Select it start the pattern command.
Use the Arc and Fit options.
Click to place the arc centre.
Then click to place the start at the original hole centre, then define the sweep anti-clockwise.
Make the sweep 200°, and the count 5 (= 4 pitches of 50°)
You can dimension the arc angle using Smart Dim - note the options for radius, diameter, length and angle.
Click return.
You should now see 5 holes along the arc, starting from the original.
Now go back and edit the pattern profile.
Select the arc and the parameters should display on the ribbon bar.
Now click the reference point icon and select the cross marking the second instance (the first one AFTER the original hole).
Now click return.
You should now see that the pattern has shifted by one pitch, and the original hole is now the second hole in the pattern.
If you make the third cross the origin you will get a pattern symmetrical about the vertical axis.
I had NEVER realised this before !!!
I think the prompt you are seeing is just a prompt to tell you to pick something if you want to edit it - you will see it when you go back to edit the profile.
By the way, when doing patterns of holes I like to create the reference plane using the 'Features Plane' option, and then use the original hole as the feature.
Sounds like you are doing OK with SE.
bc.
Quadro FX4600.
It would be more intuitive if the the dots in the pattern command actually matched the final feature positions (so when you change the reference point, for example, the dots shift accordingly and you see what the pattern is actually going to look like). This seems like an obvious way to do it though, so I wonder why UGS didn't?
Also, I noticed when using Smart Dimension to change the sweep angle of the arc, that sometimes it would move the endpoint (which I expected) but sometimes the *start point* (which I didn't expect). Do you know what is controlling this? It seems like not knowing which end will change would limit the usefulness of Smart Dimensioning this.
Well, I think I'm doing ok with SE, but the patterning threw me a little. It's the least intuitive part of SE I've encounter so far (or perhaps just not as well explained in the documentation and tutorials) but it's coming together, thanks to your good feedback. At least I'm more comfortable using it now.
Thanks again for your input. It's been very helpful.
Pat
I was looking at V19/20 as I don't have access to V21 or ST, so some of my terminology and steps may be a bit different.
If the start-end of the arc is constrained to the original hole it shouldn't move.
Make sure you HAVE constrained the end point, not just a 'point on'.
Also there's nothing to stop you moving the arc so that it matches the pattern position - you can easily do that with an angular dimension.
It sounds like you are doing pretty well, and you are certainly asking the right questions.
bc.
Quadro FX4600.
