NDS Table 11K Question
I have 1/2" dia lag screws going through a 3/16" plate into a beam and I am trying to determine the shear strength of the screws.
NDS Table 11K only gives values for my plate thickness up to a 3/8" dia screw. Do I use that value even though my screw dia is larger?
RE: NDS Table 11K Question
It would be conservative to do that.  You could also calc out the value using the yield mode equations given in the NDS.
The American Wood Council has a great on-line connection calculator at:
http://www.awc.org/calculators/connections/ccstyle.asp
You can use it for lags, bolts, wood screws and nails.
Main member matl (wood) is chosen from a pull down menu, as is side member, which includes steel up to 1/4". (Steel is the top choice in the pull-down menu and you may have to scroll up to it.)
I've checked the output to hand calculations for three different cases (for all 6 yield modes) and I always get the same answer within a percent or 2.  It is a huge timesaver.
That is a huge time saver.. those mode equations are very tedious, thanks Jim!
