Test Methods for Matrix
There must be ASTM/SAE/AMS/Etc standards for the testing of the physical parameters of epoxy matrices...
Which are good ones? I dont really know what I want to know, I just figure I need to charecterize the properties of the resin+additive formulations.
Nick
I love materials science!
RE: Test Methods for Matrix
Normally for any material one does standard tensile testing. If you look up a datasheet for an epoxy material, for example by checking the manufacturer's sites or checking www.matweb.com, you will see what needs to be measured. You may need other measurements specific to the application you have in mind.
Chris DeArmitt
Nick,
Get thee to ASSIST and obtain a free copy of MIL-HDBK-17 COMPOSITE MATERIALS HANDBOOK -- VOLUME 1. POLYMER MATRIX COMPOSITES -- GUIDELINES FOR CHARACTERIZATION OF STRUCTURAL MATERIALS.  It has an enormous amount of information (> 500 pages).
Cory
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips Fora.
Do you want specific standards, or are you after a set of property measurements which will predict how a given resin will probably behave relative to other resins when in a composite? (Depends heavily on end use of the composite, if the latter; structural (including field, marine, aerospace secondary/primary, etc.), internal (FST), radome, circuit board, etc.)
RPstress- Thats what I want to know. What are the applicable and useful Test Specifications and Standards that apply to Polymer Matrix physical property measurement.
 I spent a decent amount of time running an A2LA test lab for physical and chemical composition on Steels, but only studied composites in school.
Cory, thanks I've got a copy of that, I'll have to re-read that section.
Demon3- I am looking more for ASTM Ennn, or SAE Xnnnn, matweb is usefull if you only need basic general data, I dont feel that it is of much value when details are required.
Nick
I don't currently have access to many standards, so I have only a very limited set of specs that don't go anywhere near covering all the vaguely useful properties. Also, most of the specs I have cover the properties of the final composite.
For instance, a resin with a higher mode I basic material toughness will probably make a laminate with a higher interlaminar toughness, but there's way to deduce one from the other.
Just in case it's useful, here is my rather feeble list of specs that have some bearing on the issue:
 AITM 1-0003 Tg Determination by DMA
 AITM 1-0005 Mode I Fracture Toughness Energy
 AITM 1-0006 Mode II Fracture Toughness Energy
 AITM 1-0019 Bonded Shear Lap Joint
 ASTM D 3165-00 Strength Properties of Adhesives in Shear by Tension Loading of Single-Lap-Joint Laminated Assemblies
 ASTM D 4065-01 Plastics: Dynamic Mechanical Properties: Determination and Report of Procedures
 ASTM D 4762 Standard Guide Testing Polymer Matrix Composite Materials
 ASTM D 5528 Mode I IL fracture toughness UD composites
 ASTM D 6671 Mixed Mode I-Mode II IL fracture toughness UD composites
 ASTM D 695-02a Standard Test Method for Compressive Properties of Rigid Plastics
 ASTM E 229-97 Shear Strength and Shear Modulus of Structural Adhesives
ASTM D638 Covers test methods for bulk resin properties.
Wes C.
No trees were killed in the sending of this message, but a large number of electrons were terribly inconvenienced.
For typical properties like, tensile, compression and flexural, you should be able to find test methods readily. When I was doing me research, it was the old BS2787 Method 350D for tensile (you have to look up the update EN specs).I can't really remember the standard I used for compression, but I do remember that i have to use cylindrical samples because it was the only way to get some of the highly crosslinked epoxies to yield,if at all, the problem is difficulty in trying to cast cylindrical resin test sample without porosity. For K1c, I use compact tension and DBT method for G1c. You can get the test methods other researchers used for testing resins especially in the area of toughening of epoxy resins.
