Eductor equation and calculations
I was wondering if any one here knew how to figure out the flowrate for the suction inlet on a eductor.
I know the motive pressure and the suction and motive inlet sizes are also known. If some could let me know what other info I will need and the equations to figure out the suction flowrate I would pull in with a given motive flowrate that would be excellent.
Thank you
RE: Eductor equation and calculations
Eductors function off the "Venturi-Effect".  Look that up within a Fluids book, and it should show all the calculations and equations needed for your solution.  You may have to make a mass-balance equation to include the suction port of the eductor and account for the sudden velocity increase of the fluid because of the Venturi-Effect.
Kyle Chandler
www.chiefengineering.net
My fluids book doesnt cover eductors, only really mentions that there is a pressure drop across a venturi, and how to calculate that...
Okay I will browse the sites listed , the eductor I'm using is a shcute and koerting coincidentally.
If any one has any additional info I would appreciate it.
Thank you
aswilson87, did you check the s-k(Schutte and Koerting) site unclesyd refereneced?
Here is their literature for a steam jet syphon with charts showing flows.
http://www.s-k.com/pdf/2A_Steam_Jet_Syphons.PDF
Ted
I contacted S-K  with my specs. I hope they will get back to me.
