How to generate the Typical impulse wave in Matlab ?
Hi all again,
To generate a typical impulse wave the code I wrote was this and could not get the required shape.
V=1;
T = 0:1e-7:tf;
i = 1;
for t = 0:1e-7:tf,
if t <= tr
X(i) = V * (1-exp(-t/tr));
else
if X(i) > (0.75*V)
X(i) = V * (exp(-t/(tf-tr)));
end
end
i = i + 1;
end
T = T';
X = X';
plot(T,X);
What some people tell me is that there is a in-built fn to do the above, please let me know if there is any.
The people who told me r quite busy and r my seniors,so can't force them u know...
H
V=1;
T = 0:1e-7:tf;
i = 1;
for t = 0:1e-7:tf,
if t <= tr
else
if X(i) > (0.75*V)
end
end
i = i + 1;
end
T = T';
X = X';
plot(T,X);
H
RE: How to generate the Typical impulse wave in Matlab ?
I can't follow what your code is trying to do, so it is hard to fix. But... below is a rewrite that runs. Also, I think you are calculaing the impulse response to an ODE. For a different type of solution, you could look at ODE solvers, or the impulse function in the control system toolbox. Also, at the command prompt, you can enter "lookfor impulse" to see what type of built in impulse solvers you have available.
John
function test1
tf=1e-6; % Add definition of tf
tr=3e-7; % Add definition of tr
V=1;
T = 0:1e-7:tf;
i = 1;
for t = 0:1e-7:tf,
if t <= tr
else
X(i) = V * (1-exp(-t/tr)); % Add definition of X(i)
if X(i) > (0.75*V) % Need value of X(i)
end
end
i = i + 1;
end
T = T';
X = X';
plot(T,X);
Thanx a lot for the solution but it does not reach 1 on the rise and does not reach 75% of the value in the end (i.e. fall time)
Any suggestions...
Also please help me out in the other query (regarding work space)
I'd be really greatful to u.
Thanx,
H
Any suggestions...
Thanx,
H
