Gross Plastic Deformation vs material definition
I have problem with practical using of Finite Element Method in header analysis. I would like to use Gross Plastic Deformation (GPD). In this case linear elastic - perfectly plastic material model should be used. Then criterion of failure is 5% plastic strain. Unfortunately I cannot use perfectly plastic material because of problem with convergence. Insted of that I used material with tangent modulus 500MPa. After that I have no problem with convergence. I am thinking whether computed plastic strain (for material with tangent modulus) can be used to check GPD criterion (plastic strain should be less than 5%). What will be difference between computed plastic strain for perfectly plastic material and for material with tangent modulus?
RE: Gross Plastic Deformation vs material definition
One thinks there must be some way to mathematically attack the elastic-plastic model for your case. It is everyday routine for the steel and reinforced concrete structural design, if masked by parctice.
Is GPD some kind of code requirement? Do you have to use elastic-perfectly plastic material model (which uses the usual linear elasticity slope to model the linear, then a horizontal slope for the plastic strains), to be conservative? Or can you use whatever elastic-plastic material model fits the data (such as Ramberg Osgood)?
section B.8.2 where Gross Plastic Deformation method (GPD) is described.
