view all iterations of loop in output file
I was wondering whether it is possible to output all the iterations of a *do loop in the output file?  Currently my Ansys is set to only output the first iteration.. Is it possible to change?
thanks
RE: view all iterations of loop in output file
Yup, just use the /nopr after the *do command
exp.
/output,test,out,,append
*do,i,1,100,1
/nopr
x%i%=i
*enddo
would output
x1=1
x2=2
x100=100
Whoops, I meant to say /gopr, NOT /nopr
Thanks!
What is the use of the '%' sign? Why doesn't xi=i work?
The "%" is a marker which tells Ansys that the following is a parameter and not the prosecution of a variable name.
