SA 350
SA 350
Good morning. Can you provide me with or point me in the right direction for the chemical composition of SA 350 lf2? I cannot find anything in ASME Section IX.
RE: SA 350
ASME B&PV Code, Section IX provides guidance for weld procedure and welder qualification and does not provide chemical composition of code endorsed materials.
The chemical composition and mechanical properties for ASME SA 350 can be found in ASME B&PV Code, Section II, Part A ferrous material specifications or if you have access to an ASTM Specification, you can locate A 350.
RE: SA 350
