Translation Problems
Hi everyone
NX 3.0.5.3
We have outsource designers using keycreator. We have them STEP out their files for us and there seem to be many problems, using STEP 214 we get an assembly tree that gives us a name and [ a number ] and a number following it. for example pin[14]34567 Using Step 203 we get components named with an id number an example of that would be id345789 I believe this is happening because key creator is not a component based system. My question to all of you is have any of you ran into this and is there a way to get it translated into UG with names like STEP214 is giving us but without the []and following numbers. Thanks in advance for any help you may be able to supply
NX 3.0.5.3
