How to Select Base Flange Sketch
I am in a situation where I need to select the base flange sketch. I have code to select "Sketch 1" but I don't know if the base flange will always be sketch 1.
Part.SelectByID "Sketch1", "SKETCH", 0, 0, 0
Could somebody help with this ? Thanks.
RE: How to Select Base Flange Sketch
I'm not sure what you mean by the "base flange".  When you look at a part on your screen, how can you tell which is the base flange?
-handleman, CSWP (The new, easy test)
Sorry for not being clear. The feature that I referring to creates the part as a sheetmetal and in my solidworks by default it is always called base-flange1 but just thinking about it now it could be a sheetmetal loft as well. I would like to select the sketch that creates the body of the part and only on sheetmetals parts so they will only have 1 body.
The Base Flange for a sheet metal part will always be the first feature in the tree, and therefor will always contain the first sketch.
cheers
But somebody could make a sketch to place a plane on or for reference then that would be sketch 1 and the Base Flange sketch would be number 2.
Doesn't a loft require two sketches?  What do you want to do in that case?
How can i make sure that i will always pick the Base Flange sketch ?
I guess that a loft might almost be too complicated then. Maybe I will just put an if statement if it is a loft then it does not work.
I have no idea what you are trying to achieve, but if you can determine whether a Base Flange or a Lofted Bend has been used, could you not use an IF statement to force the selection of a second sketch?
cheers
Dim swapp As SldWorks.SldWorks
Dim swDoc As SldWorks.ModelDoc2
Dim swFeat As SldWorks.Feature
Dim swSubFeat As SldWorks.Feature
Sub main()
Set swapp = Application.SldWorks
Set swDoc = swapp.ActiveDoc
Set swFeat = swDoc.FirstFeature
Do While Not (swFeat Is Nothing)
    If (swFeat.GetTypeName2 = "SMBaseFlange") Or (swFeat.GetTypeName2 = "LoftedBend") Then
        Set swSubFeat = swFeat.GetFirstSubFeature
        Do While Not (swSubFeat Is Nothing)
            If swSubFeat.GetTypeName2 = "ProfileFeature" Then
                swSubFeat.Select2 True, 1
            End If
            Set swSubFeat = swSubFeat.GetNextSubFeature
        Loop
    End If
    Set swFeat = swFeat.GetNextFeature
Loop
End Sub
ok lets give this one more try. Forget about lofted bends lets just focus on Base Flange.
I want to select the sketch that was used to create the Base Flange.
Example: The user makes a sketch and uses the sketch to make a plane. Now the user selects that plane and makes a sketch on it and uses that sketch to create the base flange so in the feature manager tree you have 2 sketches. How will the macro know which sketch is the sketch used to create the base flange ?
Ignore my last post. The code that you posted does exactly what I need, thanks alot.
