Balancing of High Speed Turbine Rotors.
Balancing of high speed turbine rotors details.
Speed: 4596 RPM
Type of balancing (grade): dynamic as per API-617
Biggest impeller diameter: 1346 mm
Rotor weight: 7286.6 Kg.
i want to know which type of drive system to be used for balancing of such type of rotors.
Unversal Joint drive or Belt drive system.
unversal joint drive means:-drive by coupled drive & belt drive means rotor driven by belt whilw balancing.
Speed: 4596 RPM
RE: Balancing of High Speed Turbine Rotors.
An end drive balance procedure should include indexing the u-joint/drive shaft to test for the driveshaft's influence. There will be some.
rmw
Not ours but similar. Look at the biggest one it can also be belt driven.
http://
Comparing Calcs for HP that can be transmitted with available drive diameters/rpm Vs windage HP may eliminate belt drive real quick. Paper and tape or clamshell housings may reduce windage some, but there's a limit.
Regards CM
