All motors are generators, right?
Sorry about wandering over from the circuit engineering section, but something occurred to me that I could not find the answer to using google...
If all motors can be generators (and I can clearly understand how even an induction motor can be a generator - simply apply a lower frequency to it than it is currently spinning at), how, exactly, can a shaded pole motor be a generator? Is it simply a matter of over-speeding the rotor, as in a conventional induction machine, relying on residual magnetism to initiate a then self-reinforcing magnetic field build-up?
A bit obtuse of a question, I know, but it really has stumped me this evening!
RE: All motors are generators, right?
davidbeach - I'm sure there are motors which are not practical to use as generators, but according to Faraday, they'll still work as such. More specifically, my understanding is that *any* induction machine will send current back to the AC line whenever the rotor is spun faster than the synchronous speed and that maximum current occurs in either motoring or generating mode at the "slip" speed (either below synchronous for motoring or above synchronous for generating). Have I got that right or have I bollixed something somewhere?
electricpete - the magnetizing current lags the applied voltage by 90 deg. when an induction machine is unloaded but comes into phase with the voltage as the load approaches maximum, correct? This would apply whether the machine was a generator or a motor, I would imagine. Thus, most of the "magnetizing" current in generator mode would go back to the line and only a small amount would be consumed fighting hysteresis/eddy/whatever losses (e.g. - those things that determine the efficiency).
I've just about wrapped my head around how even a series-wound DC motor can function as a generator (briefly short the motor terminals together while spinning then "catch" the inductive kickback, a la a boost converter), but the shaded pole motor really eludes me...
The magnetizing current stays 90 deg. out of phase with the applied voltage. The vector sum of the load current and the magnetizing current approaches unity as the load increases but the magnetizing component of the current stays at 90 deg. to the voltage.
I suspect that any motor that limits the load current by generating a back EMF will regenerate. In some special motors the power regenerated may be very little. An induction disk kWHr revenue meter comes to mind.
Stepper type motors or other electronically driven motors may not function as generators at first consideration. However, inductive kick is an indication of back EMF and any motor that generates an "inductive kick" is trying to return energy to the supply.
A shaded pole motor will regenerate energy but given the high resistance of the winding and the load of the shading coil, they may not be able to generate enough to suply their own losses. Even an efficient induction generator may have an operating region where the generated power is less than the losses. Some small motors may never get out of this operating region where losses exceed generated energy.
Bill
"Why not the best?"
Jimmy Carter
Anyway, thanks for your reply, Bill. It is now starting to make sense to me how a shaded pole motor can act as a generator, albeit a crappy one. The shorted turn that produces the salient pole, and leads to this type of motor being so inefficient as a motor, would also "rob" most of the energy when operated as a generator. Correct?
The inductive kickback is not proof that the motor is able to generate. Every coil or other inductive circuit produces a counter-EMF when energized and an "I don't like to be interrupted" voltage aka kickback when de-energized.
The generating mechanism is something quite different and depends on voltage generated by the rotating rotor field.
I think that it is important to draw a clear line between these two phenomena.
The shaded pole motor is not able to produce any energy that you can use. With efficiencies down in the 10 % region, one cannot hope to get any useful energy out of them. All that can be observed is that power consumption is slightly reduced when such a motor is driven over synchronous speed. A good illustration of what Bill said: "Some small motors may never get out of this operating region where losses exceed generated energy"
A stepper motor has a PM rotor and can be an efficient generator.
The SR motors probably also can generate since they run synchronously and every attempt to make them move faster should produce a braking torque, which means that power is absorbed by the shaft and therefore must be delivered to the mains. If losses do not consume that power.
Gunnar Englund
www.gke.org
Also, just to be clear, when I referred to "inductive kickback" in a previous post it was in regards another not-so-suitable motor as generator, the series dc motor (but for very different reasons from the shaded pole motor).
As I understand it, the way you get a series dc motor to act as a generator is to short it out periodically as if it were the inductor in a boost converter. The transfer function for the series dc motor is pretty non-linear so things can get out of hand rather quickly but, non-intuitive though it seems, it theoretically can be a generator...
What you say about the series motor and shorting it like the inductor in a boost converter is not anything I would subscribe to. It works just like any DC machine, albeit not so easily controlled as a shunt wound or separately exited machine.
Gunnar Englund
www.gke.org
I happily accept your correction of my statement.
Re the stepper motor, I was considering the motor and the drive electronics as a unit that may not be able to accept regeneration. Again I stand corrected. The motor itself may be a fairly efficient generator.
Bill
"Why not the best?"
Jimmy Carter
The common stepper motors with permanent magnets are really AC synchronous motors, and so can generate as easily as they motor. (Superior Electric markets the same motors as stepper motors with 4 leads or "slow synchronous" motors with 3 leads.) Many stepper users do not realize this and are unprepared for the generated voltage on a fast deceleration. Typical stepper drives these days are able to handle this well, and it is seldom that even a shunt resistor is needed.
Switched reluctance (SR) motors, which are really the same thing as variable reluctance (VR) steppers, also can generate, and with efficiencies that exceed 90% (I have seen papers proposing their use in dedicated generating applications), but there are some interesting issues.
The direction of torque generated from current in an SR motor phase is not dependent on the direction of current in the phase. Before magnetic saturation, the torque is proportional to the square of the current (which eliminates the sign dependency). So to generate torque in the direction you want, you should only have current on during half of the cycle. Any current in the other half of the cycle-- even current in the opposite direction -- will work against you. Of course, this means that SR motors cannot work from the AC mains at all.
So, to decide whether you will use the SR motor as a motor or generator, you are fundamentally just deciding which half of the cycle you will be driving current through the phase.
To generate effectively, the power electronics must provide a proper path using flyback diodes to permit the current to "pump up" the DC bus capacitors. What is then done with this regenerated energy is dependent on the application, and is now the same as with any electronically controlled motor.
Curt Wilson
Delta Tau Data Systems
Bill
"Why not the best?"
Jimmy Carter
To easily flip back and forth between motoring and regenerating modes with a series wound motor I envisioned the setup shown in the attached file, where instead of the traditional "chopper" configuration (switch and FWD in series, motor in parallel with FWD), a half-bridge is used with FWDs across both switches. When the switch in series with the motor is width modulated the motor is a motor (buck converter); when the switch in parallel with the motor is width modulated the motor is a generator (boost converter). This makes perfect sense to me conceptually but I have yet to see a book on power electronics and/or motors even explain it as much as I have in this measly post. In fact, all I have seen on the subject is the occasional "it's really difficult to use a series dc motor as a generator"... Okay, the same curves that imply infinite speed at zero load or infinite current at locked rotor also imply some really wild behavior when such a motor is a generator, but is the problem simply a matter of loop compensation being difficult or is there some other more fundamental/practical issue with using the series motor as a generator. E.g.: if a 200VDC bus is bucked down to 100V at the motor and this results in an average motor current of 100A then why wouldn't it be possible to flip over to the boost mode and turn that into 200V at 50A flowing back into the DC bus? Neglecting I^2R losses, etc, of course.
Given enough residual magnetism to start generating, the output voltage is roughly proportional to the current.
When a load is connected:
As the current increases the field strength increases.
As the field strength increases the voltage increases.
As the voltage increases the current increases.
As the current increases the voltage increases.
This runaway may be limited by saturation of the magnetic circuit, stalling of the prime mover, or electrical or mechanical failure of the load.
A generator may be compounded by adding a series winding. This gives a rising voltage with loading. This may be used to compensate for line voltage drops, particularly if the feeders from the generator to the load are very long.
Because of its inherent characteristics, a series generator has almost no practical application. I can not recall ever seeing a series generator. I have encountered heavily over-compounded welding generators for special applications.
I suppose that in smaller sizes a series generator may be made more usable by design techniques such as higher than normal winding resistance and/or designing the machine to use magnetic saturation or a variable speed drive as a limit but I can't recall seeing an application.
Bill
"Why not the best?"
Jimmy Carter
Gunnar Englund
www.gke.org
waross - what you described is exactly what I imagined would occur. So, it would seem to me that as long as the control loop response time is much faster than the L/R (or mechanical?) time constant of the motor then it should, theoretically, be possible to tame this beast.
As to where you might find, and actually want to use so ill-suited a motor as a generator? To allow regeneration in an electric vehicle...
(and yes, I know that the induction motor gives you regeneration for "free" (just command a lower electrical speed than the rotor speed); series dc motor systems still cost about 1/4 what an AC system does.)
Traction motors in locomotives are series wound. And they regenerate in many cases. The resistors used in older machines are there for starting (and for controlled braking).
Controlling a series wound DC generator is probably as easy (not) as controlling an inherently unstable air-plane. It can be (and is being) done. But it can get very nasty when out of control.
Gunnar Englund
www.gke.org
This actually sounds like a really interesting project to try out - seeing if a series dc motor can be made into a reliable generator, that is. Most (all, I think) SMPS topologies present a constant power load to a source so you ought to be able to tamp down some of the squirrelly behavior of the series DC motor by melding the two together. Keeping the regen current to a fraction of the motoring current should make things easier, too - much as you don't want to either stall a series motor nor let it run unloaded (confining operation to a much narrower part of the transfer function curve, that is).
Am I on the right track here or what? Surely somebody has done this already... any references would be most interesting.
Now, about the eddy current motor used in kW/hr meters...
An induction motor with an eddy current brake.
Bill
"Why not the best?"
Jimmy Carter
If it is broken, fix it. If it isn't broken, I'll soon fix that.
That said, even though I started off wondering about how in the heck a shaded pole motor could even *theoretically* act as a generator, the series motor/generator issue really intrigues me because there actually are applications where it would be practical to recover energy such as in vehicles, cranes, an even elevators, I suppose.
waross' post really got me to thinking about this (probably let some of the "magic smoke" out of those few brain cells in the process) so I took a few minutes today to do an experiment on a 20hp series DC motor we have at the shop. I connected my scope across A1 and F1 (A2 and F2 bonded) then powered it up with 12V from a car battery and the motor spun up to some rather sedate RPM. When a 300R/10W resistor was connected across the A1/F1 terminals the voltage dropped to just under 2V immediately after disconnecting the battery then continued dropping to zero along with the shaft rpm. I suspect that if I cut the resistor value in half I will see at least twice the voltage present at A1/F1 immediately after removing the battery power... Unfortunately, I didn't have a slew of different power resistors on hand to try this, but at least it showed that, yes, a series motor will certainly perform as a generator...
Now, waross - there is one assumption you made in your poignant explanation that doesn't exactly hold true in the real world - as the series motor cum generator delivers more power the rotor will decelerate more quickly. Only if there is infinite inertia in the rotor can there be infinite power delivered from a series generator.
So it would seem that with a high-speed analog or digital smps controller it shouldn't be too difficult to extract power from of a series motor when it is called upon to decelerate a load (whether that load be a car, crane hoist or elevator cabin, etc.).
Of course, it does seem to hold true that to do so you will need to short the motor terminals for the time it takes to allow the field/armature current to build up enough to overcome the supply voltage when the short is released. Hey, it can't be any more difficult than it was to get the Saab Gripen stabilized, right? :)
When motors (Cranes, elevators) are overhauled the load serves as the prime mover and increases the speed enough to regenerate back into the source. No free coasting motor can regenerate more power than is available in the inertia of the motor load combination. Some of that power will be dissipated as heat in the motor windings.
Bill
"Why not the best?"
Jimmy Carter
I happen to know the guy who was responsible for the aerodynamics of that plane. He was on a conference in SF, CA when the Gripen hit ground and disintegrated the first time. He got an early phone call (time difference 9 hours) and that kind of ruined his day, no more conference but lots of phone calls. Anyhow, he and his collegue needed something to eat, so they went to the Chinese on the corner. When he opened his fortune cookie it said: "You have a big problem - but you will solve it". He then did just that. Perhaps he could also build a controller for a series DC generator.
Gunnar Englund
www.gke.org
What I am trying to say is that the best way, (but not the only way) to regenerate with a series machine is to use a compound machine.
Bill
"Why not the best?"
Jimmy Carter
I agree with Waross that shunt winding is probably the best way to make a series generator functional. Admittedly, it technically isn't a purely series generator, but one you have your field established with the shunt winding, you can deenergize that coil and let the machine run as a series machine. So it still is a series generator, just the field is established within the machine rather than the controller. However with proper switching within a controller you might be able to get it to generate by using the residual magnetism to get the field to proper strength.
Anyway, TurbineGen, I am planning on doing just such a test. I have a box of 4 ohm 53W resistors which will make it convenient to increase the loading in a stepwise fashion. I just have to rig up a second, identical, DC motor as the prime mover and monitor its speed/amp draw.
Things I am wondering which this test should answer:
1. Will the series motor/generator "self-excite" when driven by a prime mover rather than energizing the motor and loading it as it coasts?
2. Can the motor/generator be used the inductor in a boost converter?
3. Does the output voltage increase as more 4 ohm resistors are paralleled, assuming the RPM of the prime mover does not change significantly?
One last thing - I can find no definitive information about using a series motor as a generator anywhere... is it just me or does someone have any dusty old tomes that might shed some light on such?
