Drops inn Reinforced Concrete Slab
I m in doubt with how to reinforce the slab panel where drop should prevail. For eg; in an interior panel whose 6.3m and 5.5 m sourounded by four columns and four beams, a drop with 50mm has to be introduced parallel to 6.3 m beam and 1.5 m inside.
RE: Drops inn Reinforced Concrete Slab
