Content Center family name/member error
Hello all,
First of all I tried doing a search looking for help with this error bu was unable to find anything.
The error I am getting is...
"An existing part file with the same name but belonging to another family has been found in the Content Center files location. This happens when more than one family uses the same file name(s) for family members. You need to change the file name setting for the current family. The existing part will be used to complete the Content Center command."
The error seems pretty self explanatory but for some reason I cannot find the place to change the file name and there is no other file with the same name in the Content Center! I am wondering if there is a way to correct this or if anyone else has had this dilemma and has solved it!
Thanks for your help in advance!
