Shell outward multiple parts
Hi!
I got a task to create a cover for for some parts. I've got parts that have to be mounted to a pcb. I tried different strategies, but it won't work my way. (especially because the antenna-part is cilindrical and mounting it to the pcb results in zero-geometry.
At first i tried an assembly but couldn't find a way to create a cover.
Then i inserted al parts together and tried to shell but that wouldn't work (it shells (outward) only one part at a time.
The feature: join seems unavailable. I tried combine but then the zero-thickness problem is blocking results.
Any (other) good ideas to create a cover for these items?
Bye!
Nienke
Bye!
Nienke
RE: Shell outward multiple parts
Jeff Mowry
www.industrialdesignhaus.com
A people who value security over freedom will soon find they have neither.
