rubber to metal - permanent adhesive required?
Please could someone recommend a rubber to metal adhesive? The rubber molding has split away from the metal, so the stronger the adhesive the better! permanent if possible.
The split can be compressed with the aid of a vice which should help things!
RE: rubber to metal - permanent adhesive required?
I did not manufacture this mounting and I have not attempted to repair the mounting. I am just after a suitable product that will make a permanent repair.
We've used this material in our plant for bonding cured rubber, and it provides a decent bond after 2-3 hours, full bond maybe after 16-24 hours. I haven't used the material myself, but people that do use it think it's pretty good.
Good luck!
Tom
