Remove ALL Part Data
Hi All,
What is the right way to take a finished part and make a copy of it and remove all links, references, custom properties, file location path, etc back to the original part?
BB
BB
RE: Remove ALL Part Data
deletes custom props
If there are external references, they ca be locked or broken. Right-click a feature w/ external refs and select from pop-up menu.
-handleman, CSWP (The new, easy test)
BB
