Synthetic Oil vs Regular (solven based refined) oils for vacuum pump
What are the advantages of using a synthetic oil on oil sealed vacuum pump applications vs using a regular solvent-based refined oils. Does it last longer? What are the disadvantages? Is it only the price.
Please help.
RE: Synthetic Oil vs Regular (solven based refined) oils for vacuum pump
If you're evacuating something that won't contaminate the oil, and I don't know what that might be, then the synthetic oil... is probably still not worth the money, because it doesn't get as hot in a vacuum pump as it would in an engine.
Mike Halloran
Pembroke Pines, FL, USA
This site may be of help:
We're actually evacuating hot gas from a cvd reactor. I'm looking into reducing the amount of oil waste generated. I want to compare the rate of degradation of both oils and ultimately increase the oil change intervals in order to generate less waste. I need to determine if by using synthetic oil the oil seal is maintained longer and pump performance will remain intact longer than with regular oil. Maybe this is not the most feasible approach. May be by looking into replacing the oil sealed pumps with dry pumps will be a better choice.
Dry pumps are always good but expensive.
I do think the time-study would be worthwhile to determine the cost-benefit analysis of the different oils. I also found that typical vacuum synthetic oils were changed anywhere from a month to 3 months (depending on process and cycles).
Dry pumps are expensive and so is accidentally dropping something into them during a bearing repair (another employee let his SS wool pad fall into the intake lobes of an Edwards Vacuum pump). Ugh...
Kyle Chandler
www.chiefengineering.net
