calculating pipe strength required for a road crossing
I am looking to see if anyone knows the calculation to calculate the pipe strength required when you have to cross beneath a roadway or railway tracks. For example I have a 6" HDPE DR17 (100 psi) pipe that needs to go beneath a set of tracks. The casing pipe has to be 12" but I am not sure of what the rating should be (i.e. DR17, DR13.5, DR11, etc). I know that the calculation has something to do with taking into account the depth of cover and the weight of that depth of cover including a standard weight that takes into account the weight of traffic.
RE: calculating pipe strength required for a road crossing
Richard A. Cornelius, P.E.
WWW.amlinereast.com
