Can i change the effective depth for reinforcement
lovely friends
i have a flat plate ,it casted over a concrete plate form can i consider the reinforcement in the lower plate as assistant to the reinforcement or i cant
RE: Can i change the effective depth for reinforcement
2. can you connect the 2 plates adequately in shear to force the 2 plates to work compositely
