Can you do a "New From" for Drafting
I created a base design with all the Drawings for this base design. When I do a new from and select the Base design how do I bring along all the Drawings?
Can you do a "New From" for DraftingCan you do a "New From" for Drafting(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesWhat is rapid injection molding? For engineers working with tight product design timelines, rapid injection molding can be a critical tool for prototyping and testing functional models. Download Now
The world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
RE: Can you do a "New From" for Drafting
In short this would give you an assembly/part template with the same behavior as a file new from with drawings tied to it.
There may be other ways but I can't of one right now, so please chip in, I'm interested if there are other ways without the PKT workbench.
Derek
My next questions are:
How do I use the template, do I now do "New From" the product with the attached drawings?
When I click the icon, linked from the catalog nothing happens. Do you have any ideas what I am doing wrong?
You can double check in the catalog file in the reference that that the type is Feature and not Document
I usually detail parts more than assemblies. So I have a drawing template with all my settings and title block items. I then goto file>New From and pick that template.
http://mtm-cadtutorials.blogspot.com/
Is there a way to update all the prints without going into each and every print and manually updating?
Also, I have a script that adds the items items from the 3d model into the title block. Is there a way to automate those two items?
Ronu
Jeff
Were you able to find a way to have every sheet in the external drawing documents update automatically once they were instantiated?
I am currently facing the same problem and have so far only been able to have 2 of the 4 drawing sheets update automatically.
I am not sure where to put a reaction that will guarantee that the views will be up-to-date. It seems every script i use tries to update the drawing before it is actually there.
Any help would be greatly appreciated!
Kind regards,
Brian Wood
Engineering Services
Concentric Asia Pacific
As Azrael said there is a tool called "updatebatch" it works great. I do not know why this is not automaticly done anyways...
"Some Parts (....) have bad context. The instantiation of this template may not work correctly."
What does this mean? Can I ignore it?
