Books and References Off Road Suspension
I am looking to design an off road racing buggy from scratch.
I have been doing some research on the web, but I was wondering if anyone could suggest some books to help with sorting out handling and suspension concepts and geometry.
It will be double A arm all around, rear wheel drive, rear engined if that makes any difference.
I have had the following 2 books recommended, would you all agree
Chassis Engineering by Herb Adams and How to Make Your Car Handle by Fred Puhn
RE: Books and References Off Road Suspension
...have you got any of Carroll Smith's books? - but I must admit off-road is a whole new ballgame in reality.
I'd be inclined to keep the design intent fairly simple - low cg, strength, travel, and keep the tires square to the ground, rather than worrying overmuch about frequency response and other rather theoretical things.
Cheers
Greg Locock
SIG:Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
There are a lot of buggies out there with VW trailing arm type setups, but nearly all of the quick buggies are A arm front and trailing arm rear.
I can buy a complete bolt in front end, but where is the fun in that!
Would those front ends have wishbones that are substantially angled backward so that the hub moves up and also backward as a twin trailing arm set up would? Just curious...
"I can buy a complete bolt in front end, but where is the fun in that!". I know where you're coming from...
Very long travel and the wheel moing back as it moves up helps a lot.
Toe camber and castor angles need to remain reasonably constant through the long travel. Some camber change on the rear helps to reduce CV joint binding to increase potentia travel.
It really is all about travel, shocker and strength. No matter how well is corners, it won't wi if you cnt negotiate bumps faster than your competitor.
On loose surfaces cornering grip is more about tyres and keeping the tyres on the ground than it is about geometry.
If you really need to hook into turns, use a touch of steering brake on the rear inside wheel and some throttle as required.
If the tyre guys advise lower pressure for traction, don't do it. Use quite high (40 odd PSI) to prevent tyre and rim damage from rock impacts. Having 4 straight wheels with air in the tyres beats a 3 wheeler anytime.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers for professional engineers
I'd expect toe control (bump steer) would be an intractable issue with long travel VW style front ends? What about lateral scrub (wheel moving substantially outward with bump), I'd imagine a problem with upwardly angled wishbones (with high GRC?), but a + on the trailing arm score sheet...
We minimised it by using the longest tie rods possible, with the inboard ends about 1" apart in the centre of the chassis. It was an issue, but everyone else also had the problem. We addressed it as best could be done at the time.
We used the GM J car steering box which was unique in that it had the inboard tie rods attach in the centre rather than the ends of the steering box. It came of a Holden Camira. The same car was the Vauxhall Cavalier and an Opel and Isuzu version was available. I don't recall their names.
We stopped off road racing before wishbone front ends came into vogue.
Pat
http://en.wikipedia.org/wiki/GM_J_platform
We used a manual rack and power boosted via a torque multiplier in the steering shaft. The power steer took some working out with valve port position and pump line pressure.
Pat
My wife had a Camira, not a fond memory. The steering suffered from severe kickback / pull / torque steer over bumpy or undulating roads, more than once ripping the wheel out of my hands. The Hillman Imp rack had a similar central tie rod location as the Camira, and was fitted to an old 'Nota' I once owned (Imp had swing axle front suspension, Nota had a somewhat similar suspension made from a divided Ford Prefect beam, the whole car being quite similar to a Lotus 6). The Imp rack wouldn't be suitable for off road use, just not robust enough. I think Citroen may have used a similar arrangement on the DS series...?
