Calculation for Pipe based heat tracing
Dear sirs I would like to ask your help for some published reference about heat tracing calculation.
I did already some search but I did not found anything I would define as usefull. I started by consulting the Piping handbook (Nayyar et. Al.) but there they describe very well the use of a program for calculation from a Company which is primary interested in selling electrical heat tracing (I agree this is for most of the applications better but not for all).
I also took a look at the sites of Thermon, Cromolox and Raychem but I feel they focus strongly on Electrical tracing.
In my specific case I would like to keep the product cool because it is sensitive to high temperatures therefore no chance with electrical nor steam calculations will help.
Rgs.
Rgs.
RE: Calculation for Pipe based heat tracing
<<A good friend will bail you out of jail, but a true friend
will be sitting beside you saying " Damn that was fun!" - Unknown>>
http://
It is a nice idea, I saw it in an earlier post. It is probably a bit too sofisticated ($$). I expect to use tubing or a metallic hose clamped to the pipe as tracer to minimize the installation expense.
rgs
To simplify matters you needn't jacket alway to the flanges.
I would definitely call CSI and get some budget numbers.
If you try tubing you will defiantly have to use a heat transfer mastic to improved the heat transfer.
Such as the following or the Thermon material.
http://ww
Picking up on the idea mentioned by unotec here are some posibilites. Depending on you local and duty cycle control could be a problem.
http://www.tex-fin.com/
Dear Unotec,
Yes, you are right about the insulation, if you are tracing it is probably better to do it otherwise you will not get a proper heat distribution (in my case heat collection). I have never seen a traced line without insulation and the energy prices now probably will foster the use of insulation.
About your second idea: the cooling is mainly for the time when the pipeline is idle. The heat that I want to remove is the ambient heat (sun, hot environment).
Dear unclesyd,
Jacketed pipe is even more expensive than the CSI solution. Due to the low temperature difference between the product and the medium is very likely to require heat transfer cement).
Kind regards
This is specially tricky when you also want to cool your pipes. This cooling will condense water and water together with two different materials will act as a nice battery.
Grtz
Ben
