Seeing a section on another page
I have a drawing where I want to put section A-A on the second sheet. What's the best way to do this?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Seeing a section on another page
-handleman, CSWP (The new, easy test)
[URL=http:/
Grant
Applications Engineer
SW2008 X64 SP 3.1
Dell Precision T5400
Nvidia Quadro FX 5600
Xeon 2.5GHz Quad Core, 4GB RAM
XP Pro X64 SP2.0
1. Create the section view on the same sheet as the parent view.
2. Right click on the section view -> Alignment -> Break alignment
3. Cut section view
4. Paste section view on other sheet.
Dave
I agree with and use DaveZR2 Cut and Paste method. I've also found that picking from the SW menu Edit -> Cut & Paste for some reason is more consistent. I discovered that back in SW2006. Some habits and hard to break
Tobin Sparks
www.nov.com
-Dustin
Professional Engineer
Certified SolidWorks Professional
Certified COSMOSWorks Designer Specialist
Certified SolidWorks Advanced Sheet Metal Specialist
Michael
Matt Lorono
CAD Engineer/ECN Analyst
Silicon Valley, CA
Lorono's SolidWorks Resources
Co-moderator of Solidworks Yahoo! Group
and Mechnical.Engineering Yahoo! Group
