type of waterstop
type of waterstop
Hey all - I am working on a large waste water treatment plant. We will have a lot of waterstops specified. I know that personal preference is a factor here but can you please tell me what type of waterstop you prefer to use/specify and why? Practicality of construction is definitely a concern, as is working the reinforcing around the waterstop. I am debating between hydrophilic and pvc but am open to any economically feasible alternative. I have not used hydrophilic but feel it may be necessary because of the waterstop interfering with reinforcing.
Thanks!
Thanks!
RE: type of waterstop
I agree with jike, use 3/8 inch thick PVC waterstops. Construction joints should be 6 inches long. Moving joints should be 9 inches long and have a centerbulb.
Make sure your specifications direct the contractor to build watertight structures and give them procedures to correct leakage.
I'd stay away from hydrophilic until it's a last resort.
PVC waterstops can be done well if drawn, spec'd and constructed properly. It is alot more foolproof than bentonite!
It takes time for the hydrophilic waterstop to activate. So if you have a gap, it will leak for a couple of days before the hydrophilic stops it. I don't like explaining this to a nervous client.
While the new hydrophilic waterstops are supposed to be better, I worry that that they'll only work for a limited number of cycles. We build concrete vessels to last more than 40 years, but I don't have data to show that hydrophilic waterstop will continue to work that long.
I'm an old fashioned type engineer. I don't like changing what works until there's a real good reason. So it's barrier waterstops for me.
