Minimum volume required to register as a pressure vessel.
I was told there was a mininum volume required for vessel to be registered as a pressure vessel. But I cannot find it in ASME code. Can anybody tell me what the volume is? Where can I find it?
RE: Minimum volume required to register as a pressure vessel.
You will find all the needed data on the requirements for PV's in U1 under scope.
Even if you don't meet the requirements as to size, pressure. etc you can still design to ASME specs.
Try this link, I went through the same I think you're going through. Give me and Doc9960 a star if it helps :)
http://www.eng-tips.com/viewthread.cfm?qid=204940&page=1
<<A good friend will bail you out of jail, but a true friend
will be sitting beside you saying " Damn that was fun!" - Unknown>>
Thanks everybody.
unotec, hope you like the star.
I take it that you found it useful?
