Relay's with low thermo voltage
There are relay´s made specially to avoid thermo voltages,
These are however hard to come by, if anyone knows of any manufactures who produce them please write a line or two
RE: Relay's with low thermo voltage
We also use COTO 3500 series relays. They are acceptable but not nearly as low EMF results as the Aeromats even though the catalog specs on them are the same. In our own in house tests we see approx. .0005 mV error over 100 degree F. The Aeromats are closer to .0002 mV.
Look at:
http://www.cotorelay.com/html/reed_relay_3500_series.htm
