non newtonian piping design
how can i get deep information about non nwtonian fluid flow?I have to design a piping system, but i haven`t found any information about how!!!
what should i do to analize those kind of system?
thanks
thanks
RE: non newtonian piping design
Good luck,
Latexman
"Pumping systems account for nearly 20% of the world's energy used by electric motors and 25% to 50% of the total electrical energy usage in certain industrial facilities." - DOE statistic
"Note: Make that 99.99% for pipeline companies" - http://virtualpipeline.spaces.live.com/
You are embarking on some work that may NOT be a mainstream engineering item. It depends on how non-Newtonian your fluid is and whether the apparent viscosity versus shear rate is time dependent or not. Study up on the subject and
Good luck,
Latexman
