Inspect minimum distance "all over" V19
Not sure that's a very good title but it's late and my brain quit working a while back.
I have a model of a sand casting.  It is based on a swept protrusion so has moderately complex surfaces.  I need to do a fit check at the next assy level of several covers that go around it.  The tolerance is at least +-.06", +-.09" on some surfaces.
So I either need to do a 'find minimum distance' between the surfaces which I can only seem to do one surface of the sand casting against one cover surface at a time OR I need to be able to add the appropriate amount of material to the surfaces so I can do an interference check.
Any ideas how best to achieve this?
Solid Edge V19 & I did a search but to no real avail.
KENAT,
Have you reminded yourself of FAQ731-376: Eng-Tips.com Forum Policies recently, or taken a look at posting policies: http://eng-tips.com/market.cfm?
RE: Inspect minimum distance "all over" V19
You can do min distance between 2 solids.
bc.
2.4GHz Core2 Quad, 4GB RAM,
Quadro FX4600.
Indeed you can, how the heck did I not see that last night.
Thanks Beach, that does about 90% of what I wanted, I'll make the over 10% up as penance.
KENAT,
